community projects
, join
GlobalTalk
, and have fun!
macaphod
NeXTcube back panel
Yes, it's me 😁. The cube is fine, I found about the pin while doing the inspection before testing the computer. By the way, I'm not...
Feb 15, 2026
L
larryc39
1. I'm going to be busy at work for the next week and a half so my chances t play with this are slowing down again, right after I got it...
Feb 15, 2026
Glenn Anderson
DISTAR LDD-103 floppy drive PROM dump
Apple I/II/III
I have two DISTAR LDD-103 floppy drives, and I thought it might be useful to dump the PROMs from them. These are drives for the Apple II...
Feb 15, 2026
VicNor
Mechanical issue with Miniscribe
Thanks! I'll try to goto the hardware store next week to find a spanner tool that'll work.
Feb 15, 2026
mnthund3r
Apple Network Server 700 boot issue
Xserve & Servers
I have an ANS700/150 that I've had sitting in my basement for 25 years. recently tried to start it up, and it won't boot past the 0>...
Feb 15, 2026
That looks to me like a threaded on nut, that probably requires a special spanner tool. You can use a needle nose pliers opened up to...
Feb 15, 2026
VicNor
This bugger. How do I remove it? Is it possible? Do I need a special tool or is it bulted on so it's impossible? I've tried to lift it...
Feb 15, 2026
Macintosh Slice - a Pre-release Color Classic
A different Color Classic came with its instruction manual. It includes a brief insert that calls out the power-up sequence. There must...
Feb 15, 2026
I just repaired another Portable that was crashing when sound played. I decided to put this board in my ultrasonic cleaner. Afterwards...
Feb 15, 2026
