I did not use Ghidra all that much. From my memory there is an error message for when encoding is struggling with a high bit-rate, I...
Feb 24, 2026
videodoctor
I'd like to be working on this effort---I brought up before, but it sounds like it's not a good idea to have a temporary "fix" that just...
Feb 24, 2026
Garrett
Great work! I saw this card on eBay as well - glad someone here snatched it up. Looks like the same RAM ICs that the PowerBook 1xx...
Feb 24, 2026
L
larryc39
Also just FYI I refined my SD slot board mount and back cover parts and updated them in the original post.
Feb 24, 2026
L
larryc39
I would not try and use heat shrink tubing, it's pretty soft and will add friction unless you can find some of the glossy stuff. Also...
Feb 24, 2026
Claus
Hi @ThePhage , I am zoomed all the way out. I have the sensor mounted 7 mm higher than original. If I move the frame some clicks(2-3))...
Feb 24, 2026
jeffburg
G4 iMac and its intense heat. A brainstorm.
I think the issue with telling if they are warm is that the plastic shell does not get warm even if the inside metal shell does. But I...
Feb 24, 2026
