Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
Geekman's World
MARCHintosh 2026 Projects
Hi folks! After three years of effort (I'm new at this and my work has also been VERY busy) I'm thrilled to unveil my mutant restoration...
Feb 28, 2026
PowerBook 180c TRACKBALL Repair Help Needed
Is there a 3rd wheel that is supposed to put pressure against the ball to the two rollers? Maybe the spring is missing?
Feb 28, 2026
The only thing i can think of then, is the friction on the roller itself, the surface might be too worn/smooth - can you replace the...
Feb 28, 2026
GlobalTalk - Global AppleTalk network for MARCHintosh 2024 (and beyond!)
Awesome 2026 #GlobalTalk image created by nanoraptor
Feb 28, 2026
jonschwenn
I was going to mention the same thing. I had a demo lab of Mac minis that I would let people access to test out data center access and...
Feb 28, 2026
MissDlys
Successful compact flash upgrade for PowerBook 3400c
HEY ! Wonderful, I also rebuilt a PB3400c, I'll talk more about in a new post after, could you tell me where do you find a new Pram ? Thanks
Feb 28, 2026
I checked the ball with my precision Mitsutoyo calipers just now, Kai, and it's 30.03mm in diameter nominal, deviating only by +/-0.01mm...
Feb 28, 2026
MissDlys
Resuscitate Logic board 3400c Li-Ion Battery
HI, it's late but I actually restaurate also a battery, I'm waiting the new cells, but if you need some values to test in my PCB... to...
Feb 28, 2026
Is the ball itself out of round?
Feb 28, 2026
PowerBook (68k-based)
I recently acquired a PowerBook 180c and found it's trackball didn't produce any vertical arrow pointer movement, so I cleaned the ball...
Feb 28, 2026
