Nominations will close March 25th. If you'd like to join the board and influence how TinkerDifferent runs in the next year,
put your name in now!
community projects
, join
GlobalTalk
, and have fun!
That should work. If there is no Master/Slave jumper, you may have to play around with the assumption that it could be default master...
Mar 3, 2026
Peter-Erik
You mean like this? https://www.amazon.nl/-/en/Adapter-3-5in-SDHC-Memory-40Pin/dp/B0C3ZLNW69 (i don't seem master slave option)
Mar 3, 2026
Arbystpossum
I replaced mine with a 120Gb drive I got off of EBay, I imagine one of those IDE to SD card solutions could work too. If you want to...
Mar 3, 2026
Peter-Erik
PowerPC G3, G4 & G5 (New World ROM)
6 Gb IDE drive is noisy any suggestions for replacement? Thanks
Mar 3, 2026
mchineboy
Macintosh Plus - Weird Startup Problem
It's got 2 1mb 30 pin SIMs in it. Unfortunately I don't have any other 30 pin sims other than what's in my Iici. Edit: The resistor is...
Mar 3, 2026
RetroTheory
Have you checked the RAM is correct and matches the cut resistors config on the board ? Sometimes resistors are cut and then RAM is...
Mar 3, 2026
mchineboy
I went ahead and reflowed all of the joints on the analog board with fresh solder. Same symptoms as before, no change.
Mar 3, 2026
Mu0n
Dark Castle is BACK!
TODAY’S THE DAY. Return to Dark Castle launches at 10:00 AM PT on Steam and the Mac App Store. ⚠️Day-one momentum matters!!!! • Grab...
Mar 3, 2026
Please share the first 5 characters of your serial number. Like "H2825".
Mar 3, 2026
Just bragging about my G4 iMac G3.
I love the LEDs in the fruit iMac g3s. That looks great! I did a similar treatment to my pmG5 and have three fruit iMacs myself. I think...
Mar 3, 2026
