Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
RetroTheory
Macintosh Plus - Weird Startup Problem
Hmm, how many chips on the SIMMs ? if its 2 or 3, its kinda hit or miss if they work. 8 or 9 is more common to work, having said that I...
Mar 3, 2026
N
niknak
hi all, new member here, looking to use updated firmware on a Reels unit I picked up off Ebay. there was a posting last year on the...
Mar 3, 2026
Peter-Erik
Thanks I will try that
Mar 3, 2026
That should work. If there is no Master/Slave jumper, you may have to play around with the assumption that it could be default master...
Mar 3, 2026
Peter-Erik
You mean like this? https://www.amazon.nl/-/en/Adapter-3-5in-SDHC-Memory-40Pin/dp/B0C3ZLNW69 (i don't seem master slave option)
Mar 3, 2026
Arbystpossum
I replaced mine with a 120Gb drive I got off of EBay, I imagine one of those IDE to SD card solutions could work too. If you want to...
Mar 3, 2026
Peter-Erik
PowerPC G3, G4 & G5 (New World ROM)
6 Gb IDE drive is noisy any suggestions for replacement? Thanks
Mar 3, 2026
mchineboy
It's got 2 1mb 30 pin SIMs in it. Unfortunately I don't have any other 30 pin sims other than what's in my Iici. Edit: The resistor is...
Mar 3, 2026
RetroTheory
Have you checked the RAM is correct and matches the cut resistors config on the board ? Sometimes resistors are cut and then RAM is...
Mar 3, 2026
mchineboy
I went ahead and reflowed all of the joints on the analog board with fresh solder. Same symptoms as before, no change.
Mar 3, 2026
