I made some progress today. I was able to adjust config in settings to get srps beta Aquacenter to play clean and smooth playback from...
Mar 3, 2026
fishgee
"Matead" indicated in his post 485 in the original thread that "The chip is in fact a LSP5523-R8A." Digikey in the US has them for 77...
Mar 3, 2026
RetroTheory
Macintosh Plus - Weird Startup Problem
Hmm, how many chips on the SIMMs ? if its 2 or 3, its kinda hit or miss if they work. 8 or 9 is more common to work, having said that I...
Mar 3, 2026
N
niknak
hi all, new member here, looking to use updated firmware on a Reels unit I picked up off Ebay. there was a posting last year on the...
Mar 3, 2026
Peter-Erik
Thanks I will try that
Mar 3, 2026
That should work. If there is no Master/Slave jumper, you may have to play around with the assumption that it could be default master...
Mar 3, 2026
Peter-Erik
You mean like this? https://www.amazon.nl/-/en/Adapter-3-5in-SDHC-Memory-40Pin/dp/B0C3ZLNW69 (i don't seem master slave option)
Mar 3, 2026
Arbystpossum
I replaced mine with a 120Gb drive I got off of EBay, I imagine one of those IDE to SD card solutions could work too. If you want to...
Mar 3, 2026
Peter-Erik
PowerPC G3, G4 & G5 (New World ROM)
6 Gb IDE drive is noisy any suggestions for replacement? Thanks
Mar 3, 2026
mchineboy
It's got 2 1mb 30 pin SIMs in it. Unfortunately I don't have any other 30 pin sims other than what's in my Iici. Edit: The resistor is...
Mar 3, 2026
