I have a dead RAM slot on my 2004 15" PowerBook G4. How would I fix it?
How did you determine it was bad (swapped sodimms to opposite sides)? Are both sodimms identical (speed, size, etc)? Did you check...
Mar 4, 2026
notabitail
PowerPC G3, G4 & G5 (New World ROM)
Hi, I was given a PowerBook G4 15" 2004 last year, and I found out one of the RAM slots seems to be dead? How would I fix it? I have...
Mar 4, 2026
speakers
Be aware that the Beige G3 can boot only from partitions in the first 8GB of the IDE drive due firmware limitations. I've had good luck...
Mar 3, 2026
Analog board - display horizontal alignment
When was your green tube transplant? Do you have pics?
Mar 3, 2026
Imaging a Bootable Mac OS 9 CD the Hard Way
Was this image 2352/2048 times bigger than the partition created from disk2s1? If so, then it does contain all of the partitions. It's...
Mar 3, 2026
scj312
For my IDE machines I use standard SATA HDDs and SSDs with the StarTech IDE-SATA adapter.
Mar 3, 2026
I made some progress today. I was able to adjust config in settings to get srps beta Aquacenter to play clean and smooth playback from...
Mar 3, 2026
fishgee
"Matead" indicated in his post 485 in the original thread that "The chip is in fact a LSP5523-R8A." Digikey in the US has them for 77...
Mar 3, 2026
RetroTheory
Macintosh Plus - Weird Startup Problem
Hmm, how many chips on the SIMMs ? if its 2 or 3, its kinda hit or miss if they work. 8 or 9 is more common to work, having said that I...
Mar 3, 2026
N
niknak
hi all, new member here, looking to use updated firmware on a Reels unit I picked up off Ebay. there was a posting last year on the...
Mar 3, 2026
