Nominations will close March 25th. If you'd like to join the board and influence how TinkerDifferent runs in the next year,
put your name in now!
community projects
, join
GlobalTalk
, and have fun!
jack 68k
Reconnaissance: Modern Diagnostics for your Classic Mac
Sounds like we had the same idea! The Universal ROM sources are helpful but some of the details of how the test commands vary on...
Mar 4, 2026
Zingerpop
I have a dead RAM slot on my 2004 15" PowerBook G4. How would I fix it?
So. I also have a PowerBook G4 with a dead ram slot, the lower one quit working on mine. I dug into this a little bit awhile back and...
Mar 4, 2026
Destroyer1976
How to remove opencore from mac pro 5 .1
I think I got rid of OCLP (OpenCore Legacy Patcher). But now Mojave just doesn't finish installing. gets near the end of installation...
Mar 4, 2026
jonschwenn
USB-Serial Adapter and Cable Options
I don't see a combination that will do USB A to Mini DIN 8-Pin? Is there a known set of cables/adapters that will let me connect a...
Mar 4, 2026
Destroyer1976
Thanks for answering so soon. "OCLP (OpenCore Legacy Patcher)" is the one I was using. I originally had 'Mojave' installed, then I...
Mar 4, 2026
notabitail
As far as I could tell they are identical, yes. They look to be the ones that came with the machine (two 512MB ones). I looked and as...
Mar 4, 2026
Volvo242GT
Plans changed a bit. I downgraded to the A1278 MBP and am planning to sell the A1286 as a project machine for someone who has an A1286...
Mar 4, 2026
Please clarify if you are using OpenCore (Dortania mostly for hackintosh) or OCLP (OpenCore Legacy Patcher). If you built an installer...
Mar 4, 2026
Destroyer1976
Intel-based Macs
I have a mac pro 5.1. I had 'Mojave' installed on it. I attempted to use opencore to install 'Sequoia'. I totally messed up somehow. I...
Mar 4, 2026
How did you determine it was bad (swapped sodimms to opposite sides)? Are both sodimms identical (speed, size, etc)? Did you check...
Mar 4, 2026
