molten_software
MARCHintosh 2026 Projects
only had to slice the PSU side off for this build, but then random bits of metal and a ton of JB weld to fill in all the gaps. printed a...
Mar 11, 2026
Arbystpossum
Optical drive removed, fans installed, There was even some space to put a little heatsink on top of the heat pipes, for extra surface...
Mar 11, 2026
mchineboy
Macintosh Plus - Weird Startup Problem
@Builde68 You've nailed it. I hadn't considered the ROMs might be at fault. I pulled the ROMs and put them into my tester/ripper and the...
Mar 11, 2026
phlogios
I created a Fluxer community for discussing game development on old macs, welcome to join to talk about your own games or if you just...
Mar 11, 2026
jdmcs
Calling all members! Would you like to join the Tinker Different Board?
Announcements
Update: Nominations are now closed. Seeing as we have only two nominations and two open board positions, it appears as if we have our...
Mar 11, 2026
PowerBook power adapter compatibility?
Actually, you can. I know people who have safely used modern AC Adapters with their Portable but those Adapters match the Apple Adapter...
Mar 11, 2026
W
Windoze
@joevt Current limited power supplys usually reduce the voltage to maintain the maximum current.
Mar 11, 2026
Mu0n
ThinkC
digesting MIDI in with C on 68k macs - video
posted a new shorts video above
Mar 11, 2026
eharmon
Reconnaissance: Modern Diagnostics for your Classic Mac
The other thing I was barking up with my experiments was the possibility to load custom ROMs over serial for development purposes. Seems...
Mar 11, 2026
Glenn Anderson
Asante MC3NB Rev G Nubus NIC - getting 10Base-T working
The 00061 is the Asante the MCNB/MCiNB, see this thread were I have a mod for that card.
Mar 11, 2026
