G
GondolinOnMyMind
MacTwister: a MacCon/Etherport/Shiva/Dayna Twisted Pair breakout board
This link works: https://www.dymczyk.com/MacTwister-MacCon-Dayna-Etherport-RJ45-breakout-fa4aa72b00f247b78a4f9f61c178e177
Mar 12, 2026
mchineboy
Macintosh Plus - Weird Startup Problem
Welp. That wasn't it. Same issue persists. I'm going to replace the sockets next, but not until this evening.
Mar 12, 2026
PowerBook power adapter compatibility?
Yes you can use them. I meant to say you can't trust them. Usually the current rating is a minimum that the adapter can supply without...
Mar 12, 2026
DosFox
Recreating the Mac's CUDA / EGRET microcontroller chips - can it be done?
I'd still sanity check it before replacing anything else!
Mar 12, 2026
D
d3jsp
Yeah, the clock should be fine since it used to turn on and boot with non-responsive adb inputs. What is strange is that mine has 5v...
Mar 12, 2026
DosFox
The 341S0788 is compatible with the Colour Classic, which I believe the Mac TV is based on. It's the CUDA that's in my colour classic...
Mar 12, 2026
D
d3jsp
Hey all, does anyone know the proper replacement for a version 2.38D cuda for the Macintosh TV? Mine didn't have ADB and I couldn't...
Mar 12, 2026
goon
Goon's Tilemaker - NES tile hacking software (MacOS software)
I will output files to a Mac PICT format. I have the library (4 bit as in a NES PPU tile) available at http://sf.net/p/goons-programs/...
Mar 12, 2026
I found some old 2006 footage of an Alibi Crawl music festival my then band played. I used my Powermac G5+Final Cut Studio to cut up the...
Mar 12, 2026
