Peter-Erik
https://www.amazon.nl/-/en/Adapter-3-5in-SDHC-Memory-40Pin/dp/B0C3ZLNW69 so order this one and will chech of this works but delivery...
Mar 14, 2026
kefkafloyd
Recreating the Mac's CUDA / EGRET microcontroller chips - can it be done?
Check to make sure the CUDA reset switch isn't shorted to reset due to cap leakage. That kept my Mac TV from booting until the switch...
Mar 14, 2026
mmaseda
Problems with buying from Japan using Buyee
Compact Macs
I recently purchased a SE/30 grayscale neck board and harness off of Yahoo Auctions using the Buyee proxy buying service. Everything...
Mar 14, 2026
N
niknak
i get an init failure with the following trace (similar for all orig. firmware)...
Mar 14, 2026
akator
An Introduction: My iMac G4 "Ichigo Daifuku"
Screen Spanning Doctor disables Apple's limitations and allows you to use an external monitor as a second display however you want to...
Mar 14, 2026
jeffburg
It can.... but it's not very nice. It's vga out only. And when the screen is present, it's mirroring only. So it's not really good for a...
Mar 14, 2026
