Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
sunvalleylaw
Planning my SE/30 Reloaded build
Ok, good consideration.
Mar 20, 2026
G
GiGaBiTe
Unless you plan on using the machine for testing, I'd avoid using the PLCC sockets, except for the ROMs. It's just one additional point...
Mar 20, 2026
G
GiGaBiTe
Asante Technologies 09-00061-00 Ethernet NuBus card Rev A
I have the same Ethernet card in my Performa 600. Recently did the mod on my card, which is one cut trace and a jumper wire. I no longer...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
It's been a long time since I put a dual slot riser in my 6360, but I remember it colliding with the frame where the TV tuner board...
Mar 20, 2026
Performa 6360 added
That doesn't work out so well, took a look at it. But if I finally get around to learning to use current PCB layout tools or rope...
Mar 20, 2026
I was missing my cMP 1,1 boot screen so I installed a Mac HD5770 into that macpro. I also took the Radeon apart prior and...
Mar 20, 2026
MARCHintosh 2026 Projects
Back from the beach and dropped the grlf off at the airport. Took a day off to crash and went a bit nuts with the grinder and wet tile...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
I think you'll enjoy the 6360 far more than the 6200CD you had decades ago. The 6200CD was a turd of a design, Apple basically took the...
Mar 19, 2026
clay
Calling all members! Would you like to join the Tinker Different Board?
Hello, I am putting my name in for a vacant position as well. I have been a member on TD since the beginning and participate on several...
Mar 19, 2026
V
V.Yakob
OrangeMicro -- Orange386
I found an interesting page here. There is also a brochure here. I'll probably leave it here as a picture, in case the resource...
Mar 19, 2026
Xyber Xcaliber piggy back board
Never restore a 128K to its inglorious stock condition! Especially important to preserve it as is if it's not the first release board...
Mar 19, 2026
Sideburn
left a message on
🌈NiziMac
's profile.
Heres a setup guide, notes on scaling and positioning and my LCD mounting bracket. Let me know if you need anything else I have a TON of...
Mar 19, 2026
