Performa 6360 added
IIRC the fan config can't really be modified in terms of where it vents from the PSU, but I'm running on fumes ATM. :sleep:
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
The cards I was trying definitely weren't full height. I think I had a low profile NIC and an Adaptec 50 pin SCSI card that was...
Mar 20, 2026
🌈NiziMac
commented on
Sideburn
's profile post.
Hey Tavis, thanks again for sending all the files and notes — I really appreciate it. I went through the setup guide and display...
Mar 20, 2026
Performa 6360 added
Yep, I took out the shelf space for tuner, but the fan is in the way for a full height card IIRC. A low profile card in the top slot...
Mar 20, 2026
sunvalleylaw
Planning my SE/30 Reloaded build
Ok, good consideration.
Mar 20, 2026
G
GiGaBiTe
Unless you plan on using the machine for testing, I'd avoid using the PLCC sockets, except for the ROMs. It's just one additional point...
Mar 20, 2026
G
GiGaBiTe
Asante Technologies 09-00061-00 Ethernet NuBus card Rev A
I have the same Ethernet card in my Performa 600. Recently did the mod on my card, which is one cut trace and a jumper wire. I no longer...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
It's been a long time since I put a dual slot riser in my 6360, but I remember it colliding with the frame where the TV tuner board...
Mar 20, 2026
Performa 6360 added
That doesn't work out so well, took a look at it. But if I finally get around to learning to use current PCB layout tools or rope...
Mar 20, 2026
I was missing my cMP 1,1 boot screen so I installed a Mac HD5770 into that macpro. I also took the Radeon apart prior and...
Mar 20, 2026
MARCHintosh 2026 Projects
Back from the beach and dropped the grlf off at the airport. Took a day off to crash and went a bit nuts with the grinder and wet tile...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
I think you'll enjoy the 6360 far more than the 6200CD you had decades ago. The 6200CD was a turd of a design, Apple basically took the...
Mar 19, 2026
