Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
G
GiGaBiTe
Performa 6360 added
I'm not saying to move the fan, just use a thinner fan. I think the stock fan is 20 or 25mm thick. You can get 15mm fans fairly easily...
Mar 20, 2026
Performa 6360 added
IIRC the fan config can't really be modified in terms of where it vents from the PSU, but I'm running on fumes ATM. :sleep:
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
The cards I was trying definitely weren't full height. I think I had a low profile NIC and an Adaptec 50 pin SCSI card that was...
Mar 20, 2026
🌈NiziMac
commented on
Sideburn
's profile post.
Hey Tavis, thanks again for sending all the files and notes — I really appreciate it. I went through the setup guide and display...
Mar 20, 2026
Performa 6360 added
Yep, I took out the shelf space for tuner, but the fan is in the way for a full height card IIRC. A low profile card in the top slot...
Mar 20, 2026
sunvalleylaw
Planning my SE/30 Reloaded build
Ok, good consideration.
Mar 20, 2026
G
GiGaBiTe
Unless you plan on using the machine for testing, I'd avoid using the PLCC sockets, except for the ROMs. It's just one additional point...
Mar 20, 2026
G
GiGaBiTe
Asante Technologies 09-00061-00 Ethernet NuBus card Rev A
I have the same Ethernet card in my Performa 600. Recently did the mod on my card, which is one cut trace and a jumper wire. I no longer...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
It's been a long time since I put a dual slot riser in my 6360, but I remember it colliding with the frame where the TV tuner board...
Mar 20, 2026
Performa 6360 added
That doesn't work out so well, took a look at it. But if I finally get around to learning to use current PCB layout tools or rope...
Mar 20, 2026
I was missing my cMP 1,1 boot screen so I installed a Mac HD5770 into that macpro. I also took the Radeon apart prior and...
Mar 20, 2026
MARCHintosh 2026 Projects
Back from the beach and dropped the grlf off at the airport. Took a day off to crash and went a bit nuts with the grinder and wet tile...
Mar 20, 2026
G
GiGaBiTe
Performa 6360 added
I think you'll enjoy the 6360 far more than the 6200CD you had decades ago. The 6200CD was a turd of a design, Apple basically took the...
Mar 19, 2026
