haydonbeagley
PowerBook 1400CS alternative floppy drives?
PowerBook (PowerPC-based)
Hi all, Just a quick thread to see if anyone has had any luck in finding substitute floppy drives that would work in the bay...
Mar 28, 2026
haydonbeagley
Powerbook 1400cs washed-out screen
I've got a 1400CS with this issue too the display upon first turning it on is washed out to the point where text and colours are nearly...
Mar 28, 2026
Volvo242GT
Problems with buying from Japan using Buyee
That is true. At least, you're more likely to get your items.
Mar 28, 2026
Volvo242GT
Firefox Dynasty is modern Firefox with the necessary code to allow it to run on the older OS X versions. Am using the 145 version of...
Mar 28, 2026
MARCHintosh 2026 Projects
The FireWire mass storage device that the Mac in FireWire Target Disk Mode is pretending to be should have a LUN for each disk (block...
Mar 28, 2026
PCI Riser Design Rework of GitHub PCIe Riser - Howto?
M.2 is 0.5 mm. mPCIe is 0.8 mm. PCIe is 1.0 mm. PCI is 1.27 mm (0.5 inch). ISA is 2.54 mm (0.1 inch). So make sure you choose the...
Mar 28, 2026
A
AlpineRaven
problem is sometimes fleabay is at higher price.
Mar 28, 2026
Public Archives of TD - WIP
I wouldn't think there's a need for an archive of YouTube videos since YouTube is less likely to go down forever, but it would be nice...
Mar 28, 2026
Yep, that PCIe card was the only thing useful that turned up when I signed up and searched GitHub today. Hoping someone might point me...
Mar 28, 2026
