Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
haydonbeagley
1400 power supply recommendation?
I power my 1400CS, PDQ and Bronze Keyboard from a 24V (5amp) Mean Well PSU which I soldered the PowerBook Connector. As when I...
Yesterday at 11:17 AM
haydonbeagley
PowerBook 1400CS alternative floppy drives?
PowerBook (PowerPC-based)
Hi all, Just a quick thread to see if anyone has had any luck in finding substitute floppy drives that would work in the bay...
Yesterday at 11:07 AM
haydonbeagley
Powerbook 1400cs washed-out screen
I've got a 1400CS with this issue too the display upon first turning it on is washed out to the point where text and colours are nearly...
Yesterday at 10:57 AM
Volvo242GT
Problems with buying from Japan using Buyee
That is true. At least, you're more likely to get your items.
Yesterday at 10:39 AM
Volvo242GT
Firefox Dynasty is modern Firefox with the necessary code to allow it to run on the older OS X versions. Am using the 145 version of...
Yesterday at 10:36 AM
jspending
Restoring Disk Images to Hard Drive?
Software | Archiving
Hi Everyone, I am stuck and am hoping someone here can enlighten me. I used Disk Copy 6.1.2 to image my PowerBook 1400's internal HD...
Yesterday at 10:34 AM
MARCHintosh 2026 Projects
The FireWire mass storage device that the Mac in FireWire Target Disk Mode is pretending to be should have a LUN for each disk (block...
Yesterday at 9:16 AM
PCI Riser Design Rework of GitHub PCIe Riser - Howto?
M.2 is 0.5 mm. mPCIe is 0.8 mm. PCIe is 1.0 mm. PCI is 1.27 mm (0.5 inch). ISA is 2.54 mm (0.1 inch). So make sure you choose the...
Yesterday at 9:09 AM
