fthain
Plastic clutch
I think it's mostly a question of compatibility with the grease — if a plastic tube broke down or turned sticky that could be a problem...
May 2, 2026
MacOfAllTrades
Released — MacDoom for SE/30
Wow thanks so much for that wealth of info. Very confused about the status bar. glad you messed with the code on the color channels...
May 2, 2026
GreenBar0n
SE/30 logic board pad question
The PSU takes a bit longer than the other boards.
May 2, 2026
mmarcott
Yes. I’ll have to do that too. Do those go as quickly as the logic board?
May 2, 2026
Yes the bin files are the same bin files that were available before, just in a zip so people dont have to choose.
May 1, 2026
chuck.dubuque
So would it be with the BIN files inside the ZIP, or you are working on BIN updates for a future release. They are at the 2026.03.01...
May 1, 2026
They can update with the existing sd card + .bin file method - just not the zip file - I might have a way to update the bootloader next...
May 1, 2026
chuck.dubuque
So @eric , there's no way to get to the new firmware-update-with-zip with a bin-on-sdcard-root? I have to do the UF2 route with a USB...
May 1, 2026
