RetroViator
InventoryDifferent - Managing your vintage device collection
Thanks. I do think the issue I was having was container-to-container communication. I was using the docker-compose.simple.yaml...
May 2, 2026
techknight
Plastic clutch
Fair point, ive always put the springs back in manually and then slid the clutch in. But, if you divide the springs the way you have...
May 2, 2026
Hey, you don’t need to have traefik for the docker-compose install. The docker-compose.simple.yaml will install all the containers in...
May 2, 2026
E
edale
H2324146BK
May 2, 2026
Lenovo Thinkpad E495 - E-Waste Rescue!
Might even be the same panel, basically any 30pin eDP panel will work, but this should be a direct drop in, for you...
May 2, 2026
K
KennyPowers
Released — MacDoom for SE/30
I already did that. It looked basically the same as with the Xceed/Bolle option disabled. I was just going to do it in-game with a...
May 2, 2026
joeventura
Blue SCSI v2 SDCard CRC Errors and Other Issues...
I think it was the card I was using, I swapped it and its more stable now.
May 2, 2026
H
Hook Line and Tinker
What are the first 5 digits of your serial number?
May 2, 2026
V
V.Yakob
Driver search for OrangeMicro Grapper+ SCSI + Serial
Success! I managed to download it from the archive. Earlier I had problems with downloading files from here. I added it to the...
May 2, 2026
MacOfAllTrades
I don’t know (or I would a fixed it by now :) ) but you could test your theory based on the QuickDraw things you quoted by setting the...
May 2, 2026
