That is normal for the hacked firmware, playback is broken. To improve the image quality, more memory is used for capture, so on the...
May 2, 2026
MacOfAllTrades
Released — MacDoom for SE/30
I won’t jump to removing the xceed option yet — but you can test it both ways. I’ll add gamma and wht pt / blk pt correction to all...
May 2, 2026
K
KennyPowers
I would first try getting rid of the dedicated "Xceed/Bolle" option (go back to the 1.1.0 code), and then applying the gamma correction...
May 2, 2026
MacOfAllTrades
I think i have the right-sized fix and TLDR it’s the same net result you’re proposing — use the luminance calc i have in there now but...
May 2, 2026
RetroViator
InventoryDifferent - Managing your vintage device collection
Thanks. I do think the issue I was having was container-to-container communication. I was using the docker-compose.simple.yaml...
May 2, 2026
techknight
Plastic clutch
Fair point, ive always put the springs back in manually and then slid the clutch in. But, if you divide the springs the way you have...
May 2, 2026
Hey, you don’t need to have traefik for the docker-compose install. The docker-compose.simple.yaml will install all the containers in...
May 2, 2026
E
edale
H2324146BK
May 2, 2026
Lenovo Thinkpad E495 - E-Waste Rescue!
Might even be the same panel, basically any 30pin eDP panel will work, but this should be a direct drop in, for you...
May 2, 2026
K
KennyPowers
I already did that. It looked basically the same as with the Xceed/Bolle option disabled. I was just going to do it in-game with a...
May 2, 2026
joeventura
Blue SCSI v2 SDCard CRC Errors and Other Issues...
I think it was the card I was using, I swapped it and its more stable now.
May 2, 2026
H
Hook Line and Tinker
What are the first 5 digits of your serial number?
May 2, 2026
