T
AsantéFast 10/100 NuBus network card
On any of the X100 family, I strongly recommend installing Connectix's Speed Doubler. Apple had not made the 68K interpreter caching...
May 2, 2026
techknight
Plastic clutch
STL
May 2, 2026
techknight
Plastic clutch
Well I tried it, seems to work alright. Since this isnt an everyday machine I bet itll hold just fine.
May 2, 2026
Mark_W
SE/30 Reloaded no sound
I think those are jumper pads to bypass headphone detection in the 3.5mm jack: If you short them sound should be routed to the opamp...
May 2, 2026
MacOfAllTrades
Released — MacDoom for SE/30
Ok - same link as before (https://github.com/retrospectmike/MacDoomSE30/blob/main/DoomSE30.bin) It has an updated binary. Give it a...
May 2, 2026
T
ThePhage
Playback function from the scanner has been broken in the recent firmware mod efforts. It is documented in the user guide: As to the...
May 2, 2026
That is normal for the hacked firmware, playback is broken. To improve the image quality, more memory is used for capture, so on the...
May 2, 2026
MacOfAllTrades
I won’t jump to removing the xceed option yet — but you can test it both ways. I’ll add gamma and wht pt / blk pt correction to all...
May 2, 2026
K
KennyPowers
I would first try getting rid of the dedicated "Xceed/Bolle" option (go back to the 1.1.0 code), and then applying the gamma correction...
May 2, 2026
MacOfAllTrades
I think i have the right-sized fix and TLDR it’s the same net result you’re proposing — use the luminance calc i have in there now but...
May 2, 2026
RetroViator
InventoryDifferent - Managing your vintage device collection
Thanks. I do think the issue I was having was container-to-container communication. I was using the docker-compose.simple.yaml...
May 2, 2026
techknight
Plastic clutch
Fair point, ive always put the springs back in manually and then slid the clutch in. But, if you divide the springs the way you have...
May 2, 2026
Hey, you don’t need to have traefik for the docker-compose install. The docker-compose.simple.yaml will install all the containers in...
May 2, 2026
