  • E
    in case anybody else has this problem the answer is erase the sd card with the kodakreels software and then restart it should then work
  • kefkafloyd
    Here's a curiosity for these Hook chassis analog boards: In Apple's Service Parts Identifier guide the Mac TV analog board is called...
  • RetroViator
    I’ve had the Mac-o-Meter plugged into the external floppy port while running the IIsi through its paces and not noticed any significant...
  • I
    indibil replied to the thread G4 Cube FireWire issue.
    @François Yes, that's what I thought, but the Cubes that use diodes come with LMs, while mine, without diodes, uses an LMJ. I can't find...
  • François
    François replied to the thread G4 Cube FireWire issue.
    I’m pretty sure the diodes are needed. It’s a factory bodge, it’s manual labor, you don’t do it unless it is absolutely necessary!
  • fogWraith
    fogWraith posted the thread Hotline! in Software.
    This is a fairly ambitious project, while supporting (hopefully) all known Hotline client / server features, there are also extensions...
  • JDW
    JDW replied to the thread LC520 Overclock.
    Probably bad documentation because I’ve only ever seen those three resistors, and all three, perpetually mentioned. This is yet another...
  • David Cook
    If this is a 5120, it is a common issue that powering up sound (for the chime) introduces electrical noise into the 5V line and...
  • Trash80toG4
    Trash80toG4 replied to the thread What did you cook today?.
    Yer KILLIN' me!!!!!! Mouth is watering thinking about that. 😋 edit: BTW the flavored oatmeal is Blueberries & Cream, stands alone...
  • Certificate of Excellence
    I grew up on a farm too. Loved that life. Tacos were made. I ended up taking the belly to a crispy chicharrones. Tossed em with a NM...
  • kefkafloyd
    kefkafloyd replied to the thread LC520 Overclock.
    Fun thing I found while doing some research: The Apple service parts database from the 1997 Service Source CD-ROM specifically calls...
