G4 Cube FireWire issue
I’ve been following this as I’ve always wanted a cube and figure someday maybe I’ll run into one that will jump into my office and...
May 6, 2026
E
edale
in case anybody else has this problem the answer is erase the sd card with the kodakreels software and then restart it should then work
May 6, 2026
kefkafloyd
Mac LC 575 Analog Board Recap Guide Photos
Here's a curiosity for these Hook chassis analog boards: In Apple's Service Parts Identifier guide the Mac TV analog board is called...
May 6, 2026
RetroViator
CayMac IIsi Mean Well PSU Replacement
I’ve had the Mac-o-Meter plugged into the external floppy port while running the IIsi through its paces and not noticed any significant...
May 6, 2026
I
indibil
@François Yes, that's what I thought, but the Cubes that use diodes come with LMs, while mine, without diodes, uses an LMJ. I can't find...
May 6, 2026
François
I’m pretty sure the diodes are needed. It’s a factory bodge, it’s manual labor, you don’t do it unless it is absolutely necessary!
May 6, 2026
fogWraith
Hotline!
Software
This is a fairly ambitious project, while supporting (hopefully) all known Hotline client / server features, there are also extensions...
May 6, 2026
LC520 Overclock
Probably bad documentation because I’ve only ever seen those three resistors, and all three, perpetually mentioned. This is yet another...
May 6, 2026
Mac Portable 5V Line and Troubleshooting
If this is a 5120, it is a common issue that powering up sound (for the chime) introduces electrical noise into the 5V line and...
May 6, 2026
What did you cook today?
Yer KILLIN' me!!!!!! Mouth is watering thinking about that. 😋 edit: BTW the flavored oatmeal is Blueberries & Cream, stands alone...
May 6, 2026
I grew up on a farm too. Loved that life. Tacos were made. I ended up taking the belly to a crispy chicharrones. Tossed em with a NM...
May 6, 2026
