luRaichu
TAM - Aux PSU for Expansion Card(s) in Development . . .
Hi, USB PD 3.1 supports up to 240W, should be plenty for a TAM. It can only output one voltage at a time, you would need a power supply...
May 12, 2026
Hardware
. . . hopefully! Start of this project was info about the anemic TAM PSU issue from many sources, here, MLA, WWW and ThinkClassic...
May 12, 2026
JeffC
Iris Indigo - 12V rail problems
I have tried with two known-good PSUs, and the symptoms are the same with either. Both PSUs also output 12V fine when bench-tested...
May 12, 2026
luRaichu
Is there a broken connection inside the PSU?
May 12, 2026
JeffC
Silicon Graphics (SGI)
Hi all, I am troubleshooting an IP20 Indigo (R4400/Elan) that was working until a couple months ago. Current symptoms on power-on are...
May 12, 2026
mizerable
Can confim 2.0 rom slow as piss. That makes sense why i didnt noticed any difference between the 256k and 512k sim, as well as mac os...
May 11, 2026
TwiSlot PCI Riser and ComSlot2 NIC repro in widened CS riser form factor
2 years later . . . Yeah, I've got references about inadequate power in the TAM over on the MLA. It looks like a 6x00 PSU, but you...
May 11, 2026
fishgee
Here's what should happen when you insert the power cable (12V @ 1.5A), and press the Power button: 1) White power LED illuminates 2)...
May 11, 2026
Rand Miller Extended Myst Interview from 2020
Software & Operating Systems
Thought this was interesting and wanted to share here as well, via vga256 @
[email protected]
May 11, 2026
ScutBoy
Hotline!
the ancient history major in me salutes you!
May 11, 2026
G
GilDS
Hello, Thank you for your reply. Yes, I've already taken the necessary steps about replacing, and this resulted in a refund and the...
May 11, 2026
