Right. We'll need an nvramrc script that loads code from a partition like my Open Firmware Extender for Open Firmware 2.4 (Beige G3). I...
May 18, 2026
T
Apple used the AM79C950 on the ANS and PCI PowerMacs (and AV Quadras). It was code named CURIO. Is your datasheet for the AM79C950, or...
May 18, 2026
What did you cook today?
That’s awesome. I love it :) This weeks meal plan includes sloppy Joes but through the same mash-up lense as your brother. I use Mexican...
May 18, 2026
Yes, I'll do the SCSI driver as well, though that should be easy using the same process as the video ndrv and it doesn't remove the...
May 18, 2026
ScutBoy
Iris Indigo - 12V rail problems
Yes - it will probably come to that. I hope it obvious enough to figure out the issue once I isolate which board it is. It's hard enough...
May 18, 2026
You just reminded me of something my brother makes. Chili, but topped with mashed potato and cheese. Mexican cottage pie, basically.
May 18, 2026
GreenBar0n
Macintosh SE/30 weird issues.
Ultrasonic bath would be a great idea, I see the flux everywhere too. @Duke09, just to be 100% clear: if you were to only insert 4Mb of...
May 18, 2026
I can't tell from the photos, if it is light reflection or jpeg artifacts, but the lower half of the board seems to be covered in a lot...
May 18, 2026
D
Duke09
There was not a whole lot of corrosion. The bodge seen was from me ripping a pad. Swapping from bank 0 and 1 or vice versa results in...
May 18, 2026
JeffC
You could run it without the video board and see if it still freezes, that would narrow it down to the CPU board or video board. I built...
May 17, 2026
