A
antonioos
CFFA Version 2.0 Rev B mounted in IIgs
In your expert opinion, is this interface still valid? Thank you very much.
May 18, 2026
I think you would be better sticking with the CF card. I see from the mfr website, they don't have an v2.0 card info. They dropped the...
May 18, 2026
A
antonioos
Apple I/II/III
Hi, I have this card in my GS. I'd like to know if I should use an IDE hard drive or stick with the CF card. Unfortunately, there's...
May 18, 2026
T
Very nice. Thank you. Looked for that off and on for the last ~30 years... I know I've browsed bitsavers before. Either it was...
May 18, 2026
I guess DingusPPC mentions the Am79C940 datasheet because a Datasheet for the AM79C950 doesn't exist. Actually, a Datasheet does exist...
May 18, 2026
Right. We'll need an nvramrc script that loads code from a partition like my Open Firmware Extender for Open Firmware 2.4 (Beige G3). I...
May 18, 2026
T
Apple used the AM79C950 on the ANS and PCI PowerMacs (and AV Quadras). It was code named CURIO. Is your datasheet for the AM79C950, or...
May 18, 2026
What did you cook today?
That’s awesome. I love it :) This weeks meal plan includes sloppy Joes but through the same mash-up lense as your brother. I use Mexican...
May 18, 2026
Yes, I'll do the SCSI driver as well, though that should be easy using the same process as the video ndrv and it doesn't remove the...
May 18, 2026
ScutBoy
Iris Indigo - 12V rail problems
Yes - it will probably come to that. I hope it obvious enough to figure out the issue once I isolate which board it is. It's hard enough...
May 18, 2026
