ZX Spectrum Max 128 PAL/RBG/Composite video out advice
You could probably get a Double-Pole-Double-Throw switch and wire it so you could switch from original PAL to NTSC and back (one...
May 24, 2026
sinisterpisces
[Working, Never-Serviced Centris 650] What do I need to fix/replace before it explodes?
Macintosh Quadra & Centris
Hello, I've got a Centris 650 that I know turns on and works--or at least doesn't have a problem that I've found yet. The previous...
May 24, 2026
Found the silly TAM/G3/SATA vid, funny he made no mention at all of the obvious FatBack incompatibility. :rolleyes: Previous...
May 24, 2026
T-Man
Anyone out there with PAL/NTSC experience? I'll start by saying I'm amateur so my terminology below may not be correct. This computer...
May 24, 2026
This is what I was want to do when I was derailed with the Type D release. Currently Vision 3 negative is very poorly handled, as the...
May 24, 2026
Z
zetagi
Hi everyone, I'm new here. Is there a way to scan negative film, such as Kodak Vision 3, or are there plans to add this feature? It...
May 24, 2026
S
snes1423
SCSI CD emulator for PDQ?
How would I do that? I’m using recovery CD software, but I’m not sure if there are specific files or system enablers needed to allow a...
May 24, 2026
joeventura
[Opinion/Help needed] battery bombed SE/30 logic board
Ship to tthe US? how much?
May 24, 2026
Yep, very intrested in benchmarking the ATA133 differencial, but it's pretty far down my list due to its unicorn status. I've seen very...
May 24, 2026
Wondering why there could be a difference in performance between the two slots? It's an exact duplicate of the 6x00 riser, I'd think any...
May 24, 2026
robin-fo
I have spare ones with the bottom pre-populated which I could send to Germany.
May 24, 2026
H
Hanno
Thanks for your quick reply. Too bad that means bad news for my board. Is this seller for logic boards legit...
May 24, 2026
robin-fo
Nondestructively convert case-sensitive volume to case-insensitive one?
Whatever you do, back up your files first....
May 24, 2026
