V
V.Yakob
What did you cook today?
And this is what I cooked yesterday. 1. Pasta 2. Feta cheese 3. Zucchini 4. Different spices 5. Turkey or chicken 6. Olive oil -- This...
May 25, 2026
Duly noted, will be putting together a todo list. Should I bench same setups in the stock 6x00 as a control...
May 25, 2026
SCSI CD emulator for PDQ?
Make an image of the 8.1 CD as an iso, then set it up on an external BlueSCSI/ZuluSCSI or similar. They can directly emulate a CD-ROM...
May 25, 2026
GreenBar0n
Macintosh SE/30 Vertical & Horizontal Bars on Display "Simasima" Repair Guide
Thanks for confirmation with your experience. I've since come to realize that those clock frequencies that are shown on pg. 46, are...
May 25, 2026
If the CD is bootable, then copying all of it to a hard disk partition should make the partition bootable. Then you boot that partition...
May 25, 2026
There shouldn't be a difference. The point of the test is to prove it. If there was a problem, then it could indicate too much noice on...
May 25, 2026
mattsoft
Hey @GreenBar0n - I'm troubleshooting a simasimac se/30 and can confirm your ROM SIMM findings when performing the ROM address walk. The...
May 25, 2026
ZX Spectrum Max 128 PAL/RBG/Composite video out advice
You could probably get a Double-Pole-Double-Throw switch and wire it so you could switch from original PAL to NTSC and back (one...
May 24, 2026
sinisterpisces
[Working, Never-Serviced Centris 650] What do I need to fix/replace before it explodes?
Macintosh Quadra & Centris
Hello, I've got a Centris 650 that I know turns on and works--or at least doesn't have a problem that I've found yet. The previous...
May 24, 2026
