A
ArjenCNX
Custom 9.7" Display (iPad 1,2,3) for Apple //c with STL files and build guide [Draft: work in progress]
Wow looks smoooth! also just the right color, and i like the modified knobs allot, looks really neat! meanwhile i have added the...
May 26, 2026
T
Flashing AEC6280 for Mac use
I had an Adaptec 3940U I converted way back when. Desolder/solder the PLCC32 EEPROM. Didn't work, until some nice fellow recommended...
May 26, 2026
Dave928
Apple IIe floppy disk differences
there was no Disk I. Disk II and pc floppy drive are not compatible.
May 26, 2026
T
tistan01
LCII Doesn't Boot from SCSIKnife
I've finally recapped the LC's board! And now... More problems. Now it doesn't chime when a monitor is connected to it, and it still...
May 26, 2026
T
ttyR2
No, I didn't. I'll clean the flux off, but there wasn't much. I also checked under a microscope to make sure I didn't leave any solder...
May 26, 2026
T
ttyR2
Power Mac G4 Quicksilver main case fan replacement
If you are careful, I imagine you could spray-paint one of the Noctua's back to black. If you go lightly, it should affect the sound or...
May 26, 2026
T
ttyR2
In my beige G3, I used one of the generic IDE-CF adapters and a 32GB CF card partitioned to 8GB/24GB and it works great. A lot snappier...
May 26, 2026
T
Yes it should. Did you clean up after soldering the resistors? Even if there's no solder bridges, residual solder flux can cause...
May 26, 2026
FYI, mine turned out pretty good. Had to make a new version to handle the much different button board and controller. The cutouts for...
May 26, 2026
