VRAM - more speed, or just more colors?
Have a link to that?
May 27, 2026
I'm developing a real LOATHE/Hate relationship with that damned Tango 2! First off was the non-booting problem I caused myself when I...
May 27, 2026
geerlingguy
Just printed my first object with this filament — it seems to be a tad bit more oozy than others (at same humidity level), and it also...
May 27, 2026
AFAIK, the only NuBus Card to ever outperform onboard video (which is the rough equivalent of PDS video) would be the bit bangin'...
May 26, 2026
Mark_W
Mac SE - sad Mac
Did you check your ram sticks in another mac? Or put known good rams in it? Pretty sure it's a ram issue, I had an se showing the exact...
May 26, 2026
Normally, adding more VRAM will enable higher resolutions and/or bit depths. But in my experience with vintage Macs, a switch to higher...
May 26, 2026
roymaya
Mac SE - sad Mac
Compact Macs
I have an SE that has stopped working. I replaced the power supply with a Seasonic a few years ago. I checked voltages they're fine...
May 26, 2026
L
lazybluegoat
Replacement model label for LC475?
Macintosh LC & Performa
I have an LC475 that is missing the model label from the front of the computer. I’d like to replace it, but I haven’t been able to find...
May 26, 2026
