Froggy814
Thanks for the confidence. I might just pry it open now that I know it won't look too bad after prying it open.
May 28, 2026
VRAM - more speed, or just more colors?
@ClassicHasClass I used Gemini to glean relevant info from your URL about the Apple Display Card 8•24 GC.... 1. The Hardware Under the...
May 28, 2026
campbellashe
The case survived my screw driver prying method from the entry point of the cable. I used some small shims to get it open. Nothing...
May 28, 2026
T
Radius ThunderColor PCI Uses Same Chips as Thunder IV GX Nubus
Just saw this on Ebay: https://www.ebay.com/itm/306945112145 And notice that the main chipset is the same as the valuable Nubus cards...
May 28, 2026
Froggy814
No, I was to afraid to open the original brick (because of the glue and snapping it). But I can take measurements for you. I've also...
May 28, 2026
E
Eradicator
Hello all, new to the forum, and have ordered a Kodak Reels from the Amazons to scan a bunch of 8mm and Super 8mm with sound. I'm...
May 28, 2026
campbellashe
Did you stick it back in the Original Power Supply Brick?
May 28, 2026
Froggy814
FYI, I used a usb-c power board and a buck converter and combined them to make a replacement power supply run fully off usb-c. These...
May 28, 2026
campbellashe
This is a screenshot of TechKnight's board that is Dremeled and clean that I used to check continuity....
May 28, 2026
campbellashe
Well. I just placed some small wires to extend the areas broken. The transformer fit fine with some careful guidance. Power supply is...
May 28, 2026
