Setting the property to 1 from Open Firmware indeed enables on-board Ethernet with 1.1.20.1. Now to think about if we want to solve...
May 30, 2026
5500 board won't POST/chime w/o the Display hooked up?
Beige PowerPC (Old World ROM)
I've got a test rig that'll boot Alchemy and Gazelle boards with no problems at all, but not my AIO 5500 sub-variant of Gazelle. Does it...
May 30, 2026
MRB2026
Hello from Tucson - Quadra 840av, Colorsync, G5, G4 mac mini, misc pc's
Introductions
Hi - new member saying hello My first computer was a Z80 Apple II variant that cross-botted CPM, and then when I was about 10, I had 3...
May 30, 2026
Macintosh Mini - (yet another) Maclock conversion project
I should have posted this sooner. I have 4 extra boards if anyone needs one. However, I'm about to be away from home for 3 weeks, so...
May 30, 2026
wells
It looks like PCBway will print the STL for this project in PLA (or any other FDM filament) whereas JLCPCB has a 30x30mm minimum.
May 30, 2026
Mark (Millennium Macs)
IIci PSU - Dead as a Dodo
I think I had to leave 2 due to not having stock, one was the small guy on the vertical daughter-board, the other was a 4.7uF I didn't...
May 30, 2026
@wells Have you put your STL files through the JLC3DP website to see if the size is large enough for them to do a PLA print? They have...
May 30, 2026
Right. ANS 2.0 ROM will use the AAPL,9500 identifier even if it detects itself to be an ANS machine. An ANS machine (whether using ANS...
May 30, 2026
The PLSCCPort property is set by ANS 2.0 Open Firmware. It is not set by any other version of Open Firmware. 1 is for ANS 7 is for TNT...
May 30, 2026
