A
ArjenCNX
still working on this, it seems my 60V is always too high at 80+V , the other voltages are in check, at 8 and 24V. quite strange to me...
Jun 9, 2026
Portable CCFL Backlight Replacement with Off-the-shelf LED Strip Driver
Correct. For the first item, I've ordered a couple of other small step-up converters to test. There is one other possible negative...
Jun 9, 2026
@David Cook You're like Scotty -- a real "miracle worker." I'm floored by the excellent detailed info you provided. You, sir, are to...
Jun 9, 2026
Macintosh Portable
I bought a backlit Macintosh Portable (M5126) that needed a recap and minor cleanup. Upon powering up, everything initially worked...
Jun 9, 2026
What did you cook today?
I'm starting to ignore your posts like I do the news, one is fattening when I gaze upon it and the other is infuriating when I read it...
Jun 9, 2026
RetroTechTom
PowerBook 3400 small popping noise when plugged in
Yes I did take apart the PowerBook to remove the PRAM battery and thankfully it didn't leak inside of it
Jun 9, 2026
RetroViator
Dell System 310/325
Thanks to some help on the Vogons forum, I figured out the problem with my CPU and cache controller. The orientation was correct, but...
Jun 9, 2026
Logic Board - Macintosh SE Reloaded
It’s actually pretty critical because I have accidentally reversed the cable I was inserting on the internal SCSI connector on my SE/30...
Jun 8, 2026
Kris92
I will post a picture as soon as my board will be assembled (1 or 2 weeks maybe). But only one issue can be fix. The other one can't be...
Jun 8, 2026
