T
Beige PowerPC (Old World ROM)
So I understand that 72 pin SIMMs use the /RAS signals to distinguish between and separately activate different banks. How is this done...
Jun 10, 2026
Portable CCFL Backlight Replacement with Off-the-shelf LED Strip Driver
Noise suppression of ceramic caps is sometimes done by drilling holes in the board around the cap so the PCB won't act as a speaker...
Jun 10, 2026
techknight
Thats only slightly high but its not too far off. It also needs to be under a load from the flyback producing HV before you can really...
Jun 10, 2026
jonschultz
Sounds almost like it's in high-res mod mode, but I assume that's not really the case. :) Have you looked at pot PP1? I don't think you...
Jun 10, 2026
Not certain. But, I agree with you that noise can be a showstopper. For example, all of my recent PCs have beQuiet cases and fans.
Jun 10, 2026
@David Cook Are you 100% certain its the coil and not the cheap ceramic caps? The expand and contract in some circuits, and like a...
Jun 10, 2026
I just tried it. I drowned the coil in superglue and let it sit for an hour. It is dry to the touch. Unfortunately, the coil whine is...
Jun 10, 2026
nubus_bagel
SPARCstation IPX power issues
Sun Microsystems
I picked up a Sun SPARCstation IPX at VCF SW, and I'm having trouble getting the computer to power on. I recapped the power supply, and...
Jun 9, 2026
I asked google "coil whine hot glue solution?" It says No, hot glue has a low melting temperature. Links to here for other solutions...
Jun 9, 2026
