A
AppleTree
I broke and fixed Macintosh Portable (backlight). Attached backlight circuit schematic that I reverse engineered
Macintosh Portable
I bought a Macintosh Portable backlight model a while ago and I finally got around to working on it. The case and screen were in almost...
Jun 11, 2026
U
ufkel
USB-Serial Adapter and Cable Options
FWIW, here is my setup: I found some short DB-9 (male) to Mini-Din-8 (male) cables in my grab box. Checked them with a multimeter. All...
Jun 11, 2026
T
The schematics show the wiring, but not the behavior. I've also crawled through the Hammerhead ERS document and it does not shed light...
Jun 11, 2026
I updated FreeTube to 24.0.1. I assumed the manual install would overwrite the app but it did not. It installed the updated version...
Jun 11, 2026
A
ArjenCNX
Yeah, i know that as well, it seems complex as i have also used some cross-reference parts for several things, such as QL2, some diodes...
Jun 11, 2026
RetroViator
Dell System 310/325
Wiring up a DIN connection is never fun, but it happened. I was able to determine which pin on the motherboard was connected to vcc and...
Jun 11, 2026
On the DingusPPC Discord, you can find some memory controller documentation. Search for these: filename:Platinum_ERS_1.0.pdf...
Jun 11, 2026
splorp
Newton MP2100 Repair
I would suggest contacting Frank Gründel at PDA-Soft. He is the most knowledgeable person I known for determining what to do with...
Jun 10, 2026
How to: Use Ollama with unsupported GPU
Unfortunately, i'm running the latest BIOS and it still only shows 2GB that i can allocate, as max. Probably because this is the...
Jun 10, 2026
S
Surfingmonkeys
iPad, iPod, Newton/eMate & Handhelds
This was also posted to 68kMLA Hello everyone, I have a Newton MP2000 with the MP2100 upgrade and it does not power on - looking at...
Jun 10, 2026
nevarDeath
First off, THANK YOU for tinkering with an old crusty potato and posting about it! I also have a ThinkPad E14 with 16GB of RAM (8GB...
Jun 10, 2026
What did you cook today?
Yanno what is so good about having tacos for dinner? It’s that you can have them for breakfast the following morning as a crispy refry.
Jun 10, 2026
