The algorithm for Hammerhead is different than for Platinum. Platinum Bank Base registers support addresses with this mask: 0x7FE00000...
Jun 12, 2026
E
Eradicator
Ok, I did the lens swap/mod and I am on the firmwre "D" mod. But now I cannot zoom out enough to see the entire frame and sprocket...
Jun 12, 2026
Mark_W
If HOT is not shorted and CRT PSU does not enter protection mode after it tried to start initially, then the fault might not be in the...
Jun 12, 2026
A
ArjenCNX
okay now i have checked the board one more time, and i cannot see any errors there anymore, i did fix 2 connections before, now i have...
Jun 12, 2026
SPARCstation IPX power issues
This might be a question for @This Does Not Compute !
Jun 12, 2026
T
I wonder if this is an artifact of using the same ROM on both the PowerSurge and Catalyst machines. PowerSurge doesn't support...
Jun 12, 2026
ATTinyRTC: RTC Replacement for SE/30
Compact Macs
Many of you are already aware of Phil Greenland's Github project where he uses ATTiny85 to replace the RTC (Real Time Clock) on SE/30...
Jun 12, 2026
Maybe the hardware allows it. I don't think the ROM HWInit memory detection routines for Platinum might not. I've attached startup...
Jun 12, 2026
H
Hook Line and Tinker
@StevieB I'm new as well and the experts will jump in with an answer but since the stock firmware is available for A, B, C, and D...
Jun 11, 2026
T
Looking through the Hammerhead and Platinum documents carefully, they strongly suggest that banks are controlled on a /RAS basis...
Jun 11, 2026
