Portable Misc - Hinge clip fix, Earlier features, Super Static memory
Macintosh Portable
Broken Corners I've seen enough broken cases that I lean toward being pragmatic rather than attempting a pristine repair. A common...
Jun 14, 2026
Macintosh LC III Bodge-Laden PCB
Correct. Those are factory.
Jun 14, 2026
macoslove
Macintosh LC & Performa
I am not sure about these bodge wires but I assume they are first revision last minute fixes, or at least that is the hope. No chime or...
Jun 14, 2026
RetroViator
InventoryDifferent - Managing your vintage device collection
I wanted to jump back on this thread to say I got this up and running on a Raspberry Pi 5 which is also hosting my RetroNAS setup. I'm...
Jun 14, 2026
Radius Full Page Display for Macintosh 512ke/Plus - Cloning project possibilities?
Jun 14, 2026
This Does Not Compute
created the resource
Macintosh PowerBook Duo Prototype Schematics
Documents
Schematics of a 16MHz EVT motherboard codenamed Metropolis, a prototype from early PowerBook Duo development. Since it features a 68030...
Jun 14, 2026
ATTinyRTC: RTC Replacement for SE/30
Thank you for those excellent questions, @luRaichu ! I don't have a Mac Plus in which to test it, sadly. And when I investigated Plus...
Jun 13, 2026
I broke and fixed Macintosh Portable (backlight). Attached backlight circuit schematic that I reverse engineered
Looking at the Portable driver code, I believe O1 of U13G is also connected to display J19. It appears this is the backlight enable pin.
Jun 13, 2026
Jun 13, 2026
luRaichu
Can it work on a Mac Plus? Is it as accurate as the original RTC?
Jun 13, 2026
