D
Duke09
Macintosh SE/30 weird issues.
I get the same issue with a floppy boot of OS 7 unfortunately. So something signal must be missing.
Tuesday at 3:30 AM
Froggy814
Alright, all of the mouser part's showed up, but I'm still waiting for the PCB and the aliexpress stuff... @campbellashe has taken the...
Tuesday at 1:52 AM
V
VeryVon
Fix old Quantum drives
For the ProDrive ELS, I cut a small piece of black polyethylene foam about 1/8 thick and used a piece of double-sided tape to secure it...
Tuesday at 1:43 AM
Steve Rieck
I got some beauties of my own lol… Yeah I would try a floppy boot OS 7 disk if you haven't yet and see if you have the same problem. If...
Tuesday at 12:26 AM
Elemenoh
While I was at it I measured the caps pulled from all of the other boards. So many! Power Supply RatedMeasured% DevDFNote 0.47µF...
Monday at 11:49 PM
G
GiGaBiTe
Macintosh LC III Bodge-Laden PCB
If you want a bit of extra performance, there are a few passives you can move around to change the board to LCIII+ spec and run the...
Monday at 11:03 PM
G
GiGaBiTe
Quadra Quandary Quibbles
You have corroded traces going to the VIAs in the unpopulated ROM slot between the VRAM slots and the soldered RAM. There also look to...
Monday at 10:59 PM
D
Duke09
That is my beautiful badge wire for a broken pad.
Monday at 10:52 PM
croissantking
Apple PC Compatibility Card (7" & 12") MS-DOS 6.22 / Windows 3.11 / Windows 95B / Windows 98SE Images
File copies in DOS are being heavily corrupted, as revealed with the fc (file compare) command. It applies equally to CD-ROM to HD, HD...
Monday at 10:43 PM
PowerFox - new web browser for Leopard on PowerPC!
Yes, it was a lot easier debugging it when I could run automated tests. The command line shell was massively faster at that. It won't...
Monday at 10:36 PM
