I'm right there with you, but concentrating on other wildly impractical avenues of approach to this mess for the time being. My CAD...
Jun 24, 2026
Jazzzny
PowerFox - new web browser for Leopard on PowerPC!
Yes, this is with the browser, I'll see how much I can get out, thanks.
Jun 24, 2026
That means the loader could not allocate that much stack space to your process, so you get a null pointer. If this is the browser, it's...
Jun 24, 2026
Jazzzny
Did you have to do anything special to get the larger stack to function? When I pull in the linker argument, it creates a binary that...
Jun 24, 2026
macoslove
Quadra Quandary Quibbles
Interestingly this machine came from an elderly mans basement as was untouched for quite some time and had a school district listed on...
Jun 24, 2026
If you don't do it, you'll get crashes in the browser trying to run any code of substance. The test suite will mostly run, but most of...
Jun 24, 2026
Jazzzny
Thanks, I've located your changes in the appropriate moz.build files. Do you happen to remember the reason for the stack size increase...
Jun 24, 2026
G
GiGaBiTe
The PCB under U26/27 looks really sus, like the surface of the board has been scraped away and exposed the layer underneath. Seems like...
Jun 24, 2026
Froggy814
Too bad I'm not that good at CAD yet...
Jun 24, 2026
_nec6678
Distorted Image with AppleColor High-Resolution RGB Monitor
Hello! I recently got an AppleColor High-Resolution RGB monitor at the VCF InfoAge festival this April, and it goes pretty nicely with...
Jun 24, 2026
Radius Full Page Display for Macintosh 512ke/Plus - Cloning project possibilities?
https://www.ti.com/lit/ds/symlink/cd40257b.pdf
Jun 24, 2026
macoslove
Its amazing how proper tools make the difference (or at least better tools) for look at what I see! I don't see issues with the U26 and...
Jun 24, 2026
