Show me your gardens
Man to get free water around here, you have to drill a well at about 460ft which for a fully turnkey system is about 30-32k usd all in...
Saturday at 2:38 AM
Interesting, but the Page Buffer is built up in VRAM sequentially in alternating cycles split with other CPU activity. AFAIK it never...
Jul 3, 2026
mmaseda
Horizontal lines on SE/30 Display
Since nobody else seems to have the problem I just tell you what I found. Turns out to be an issue when using a Sony power supply...
Jul 3, 2026
Well, this isn't exactly a garden, but my wife @boopbox123 's allotment. Luckily, it's only a few hundred metres from our front door...
Jul 3, 2026
Can't see the traces yet. I need to test this card, the one I got recently was listed as tested good and will be set up first with...
Jul 3, 2026
ptricky
updated their
status
I've gotten a lot of work done with compatibility with loading 68kmla and have now begun debugging macsurf loading tinkerdifferent! The...
Jul 3, 2026
I expect SOE to be tied together - that's an input. SO0 - SO3 are outputs and are probably used for the output raster. That's how most...
Jul 3, 2026
Concorde1993
Hardware/software you have that no one talks about.
In terms of software, there is a program I recently discovered called MacPalette II, which allows the ImageWriter II to print color...
Jul 3, 2026
Pi Zero's been approved as a good proof of concept platform. Just checked, Pin 5 is a data line and not tied together. Wouldn't expect...
Jul 3, 2026
Bad news just got worse from the serial output point of view, but maybe a whole lot better from mine? Pretty much verified the...
Jul 3, 2026
I'll give it a shot: That's pretty much it, butPi Zero 2 W will probably only do "every so often frames" which may or not be rotated...
Jul 3, 2026
