T-Man
Macintosh Iici build questions/MMU
Macintosh II
I have a battery bombed Iici with several legs of the MMU (and multiple traces) eaten away. Aside for the MMU, the other chips look...
Jul 14, 2026
I found the @zigzagjoe suggestion: "That card appears to be completely discrete or programmable logic. It would be simpler to just...
Jul 14, 2026
Thanks! I am always worried my one Portable PSU might blow.
Jul 14, 2026
E
Eradicator
I was only suggesting the D stock firmware because you already have a unit that cannot function. I have a D unit myself. There is...
Jul 14, 2026
This Does Not Compute
Compact Mac on a battery…
You could start by connecting the Mac to a power monitor like a Kill-a-Watt and see how much it draws. My guess is probably in the 50W...
Jul 13, 2026
F
FrenchNum
Thank you very much for your reply. Your serial number is extremely close to mine, so your scanner is probably the closest match I've...
Jul 13, 2026
F
FrenchNum
Thank you very much for taking the time to test this on your own scanner. I really appreciate it. Your experiment is extremely valuable...
Jul 13, 2026
Before I got the battery eliminator, I had a relatively cheep 7.5v 1.5A generic power supply I got off Amazon. The 18W version should...
Jul 13, 2026
Arbystpossum
G4 iMac and its intense heat. A brainstorm.
I opened and closed mine so many times, those big long screws on the bottom are starting to strip. I'm going to have to grind a channel...
Jul 13, 2026
