Garrett
4MB Macintosh II & IIx 30-pin SIMM's
I made a set of these ~1yr ago and they never worked. Thankfully I did select 1.2mm thickness (still had to shim them a little for good...
Jul 16, 2026
WowIndescribable
I kind of agree with some others who have expressed a desire for separate threads for devs, usage/settings, mods, etc. So I don't want...
Jul 16, 2026
Michael
BlueSCSI NeXT quesiton
Thanks a lot for your mail! I will follow your suggestions once I start working on the 712 again. Currently, it's part of a small stack...
Jul 16, 2026
F
FrenchNum
Thank you very much, that's very useful information. It's reassuring to know that your scanner showed exactly the same symptoms and was...
Jul 16, 2026
I
Inspector77
How to use serial MIDI both ways, from Snow emulator
Hi, this is fantastic; I’ve been testing various sequencers over the past few days, and it works really well. The only thing that isn't...
Jul 16, 2026
T
I Do Not Think There Are Enough Caps On This 7200 Board...
Ah, well, beyond the obvious of inspecting the board, that's all I've got. Hmmm. Let's see... Ah, here we go. If you do not have...
Jul 16, 2026
milek7
Mine is Europe-acquired K2225148BK01056. Yeah, exactly the same symptoms, just can't remember if it was B or C, because I tried both...
Jul 16, 2026
F
FrenchNum
Thank you, that's very encouraging to hear. Your experience sounds very similar to what I'm seeing now. It's reassuring to know that you...
Jul 16, 2026
R
Retired member 24601
I cant tell if it is booting or not (though I am certain I had a working drive connected and it spun up but no seek/work sounds past the...
Jul 16, 2026
T
Portable RAM Card 1MB -> 3MB by adding 658128ALFP chips. Is the B revision acceptable?
Too bad you can't use HM658512ALFP chips, or could you? I have about 300 of those sitting here doing nothing. Got me wondering...
Jul 16, 2026
