jonschultz
Weird discoloration on Color Classic CRT
I’ve never really heard much of a noise from a CC’s degaussing coil, so I think it’s just the case that they’re designed for pretty low...
Jul 21, 2026
8 ohm for 16 ohm speaker in Workgroup Server 9150
If I couldn’t find the right speaker I think I’d try a 5w rated 8ohm resistor in series with the 8ohm speaker which would present a...
Jul 21, 2026
Xserve & Servers
I expect this is the same for the Quadra 900/950 and AWS 95, since they all use the same speaker assembly as far as I can tell. My...
Jul 21, 2026
Apple Lisa 3d Case Project
I've got some tweaking to do on some of the parts, but I'm pretty pleased for the first full print. The seam line, while pretty good...
Jul 21, 2026
Floppy disk vertical? Disks pop out like a toaster? Aside from the concerns over dust (we could put a flip cover to protect it when...
Jul 21, 2026
JeffC
Classic II (early 4-ROM) black screen - RESET held low, no 15.7 MHz clock from EAGLE
I did quite a bit more testing this afternoon, the machine behaves identically with the replacement IIsi EGRET, so I think I can safely...
Jul 21, 2026
