Apple Lisa 3d Case Project
Ok, added a little character to the case. The Apple / Lisa logo didn’t work out as I’d hoped. I was trying to use PETG as a support...
Jul 22, 2026
gfuller
"Chime cycles" and other strange behavior from Classic
Compact Macs
Howdy, everyone. After a three or so year hiatus from the hobby, and probably five from being really into it, I'm finally getting back...
Jul 22, 2026
Weird discoloration on Color Classic CRT
I tested some of the components in the degauss circuit and everything tested OK. The solder joints on the pins to the coil look good...
Jul 22, 2026
Mike Damore
My serial number is J2925148BK01666. I flashed FWDV280-2 (after removing the "-2") without any issues. Seems these new numbers are D's...
Jul 22, 2026
8 ohm for 16 ohm speaker in Workgroup Server 9150
I'd thought about that, but the audio wasn't great to begin with and I'm worried that would make it worse. Still, as you say, if I'm out...
Jul 21, 2026
Just gave up on buzzing connections on my much corroded MagicBus card. Can't locate the good one. So will be setting up the copy stand...
Jul 21, 2026
Nope, more like these from Radio Shack used as inspiration for a Lisa-like Lisa III makeover: Do either basic bezel form factor...
Jul 21, 2026
jonschultz
I’ve never really heard much of a noise from a CC’s degaussing coil, so I think it’s just the case that they’re designed for pretty low...
Jul 21, 2026
If I couldn’t find the right speaker I think I’d try a 5w rated 8ohm resistor in series with the 8ohm speaker which would present a...
Jul 21, 2026
Xserve & Servers
I expect this is the same for the Quadra 900/950 and AWS 95, since they all use the same speaker assembly as far as I can tell. My...
Jul 21, 2026
I've got some tweaking to do on some of the parts, but I'm pretty pleased for the first full print. The seam line, while pretty good...
Jul 21, 2026
