guibrush
new Apple 1 game
well, I wrote the game specifically for the Apple 1, so, I see two solutions, get a replica or use an emulator :-)
Jul 22, 2026
Froggy814
new Apple 1 game
:( I will try to find a way! I don't have an Apple 1... It sounds fun too but I don't want to play in an EMU... At least on a modern...
Jul 22, 2026
guibrush
new Apple 1 game
nope, it's pure 6502 assembler
Jul 22, 2026
Froggy814
new Apple 1 game
Can you play it on a 68k Mac?
Jul 22, 2026
warmech
Apple Lisa 3d Case Project
For what it is worth, the only switch I ever toggle is the power switch. Everything else I've configured (including jumpers) and not...
Jul 22, 2026
guibrush
new Apple 1 game
Apple I/II/III
Hi. I created a small hacking game on the Apple 1, it's called intruders and it's a hacking simulation. Developped to run on the...
Jul 22, 2026
jojo2k
What printers are you using?
As the title says. What printers are you running? You have them networked, or connected directly to certain computers? What kind of...
Jul 22, 2026
Ok, added a little character to the case. The Apple / Lisa logo didn’t work out as I’d hoped. I was trying to use PETG as a support...
Jul 22, 2026
gfuller
"Chime cycles" and other strange behavior from Classic
Compact Macs
Howdy, everyone. After a three or so year hiatus from the hobby, and probably five from being really into it, I'm finally getting back...
Jul 22, 2026
Weird discoloration on Color Classic CRT
I tested some of the components in the degauss circuit and everything tested OK. The solder joints on the pins to the coil look good...
Jul 22, 2026
Mike Damore
My serial number is J2925148BK01666. I flashed FWDV280-2 (after removing the "-2") without any issues. Seems these new numbers are D's...
Jul 22, 2026
8 ohm for 16 ohm speaker in Workgroup Server 9150
I'd thought about that, but the audio wasn't great to begin with and I'm worried that would make it worse. Still, as you say, if I'm out...
Jul 21, 2026
Just gave up on buzzing connections on my much corroded MagicBus card. Can't locate the good one. So will be setting up the copy stand...
Jul 21, 2026
