JAG
Announcing BlueSCSI Toolbox – Web Edition
Any plans to offer/opensource a small ESP32 board that could mount next to an internal bluescsi for use in something like a Quadra700 or...
Jul 27, 2026
B
Boojakascha
I think stock D's just record super 8 at 840x624 and artificially blow it up to a higher resolution for the sharpening processing. You...
Jul 27, 2026
O
Oelmuvun
Documentation for DB15 to VGA adapters
Adding a Philips 9AVMAC-074I I haven't tested it. The opposite side if the adapter is blank, and the backside of the sheet is warranty.
Jul 27, 2026
Expansion Memory Cards and Speed Limitations above 5MB on the Macintosh Portable
That's what we suspected. So, if you average the clocks (2 + 6 / 2 = 4) over the entire memory range, you end up with the 50% slowdown...
Jul 27, 2026
Incredible work! No init needed. The 5120 Portable has a one wait state. You must be driving your 8 MB at zero wait state. That's why...
Jul 27, 2026
SuperSVGA
And if you're curious of the stock numbers from the CPU GLU: 0x000000 - 0x4FFFFF: 2 clocks 0x500000 - 0x8FFFFF: 6 clocks 0x500000 -...
Jul 27, 2026
Froggy814
Wow! 102% better! That's an improvement! Wondering about how Sideburn put (I think 13mb) of ram in his Portable, and was wondering, how...
Jul 27, 2026
L
litriSE
Running a Mac Plus logic board on an SE analog board/PSU — anyone done this?
Update: got it working (mostly)! Connected a known-good Macintosh Plus logic board (1MB RAM, booting off BlueSCSI) to a known-good...
Jul 27, 2026
campbellashe
Okay. Wow. What a difference the bodge wire and code logic change made with driving DTACK Now no slowdown at all on the 8MB card...
Jul 27, 2026
