T
tiktok4321
BlueSCSI v2 - DaynaPORT WiFi!
Sadly this apparent simple fix didn’t work for me. Back to the drawing board.
Jul 29, 2026
Froggy814
It's about the same device, but I found an another approach to take at the plug and not mangle anything. Not gonna share it until it...
Jul 29, 2026
Ah, that's correct. I had to send in my old cut cable for him to re-use the connector. Would it be possible to remove the board...
Jul 29, 2026
Froggy814
Finally was able to export my code today! Hopefully it works. Unfortunantly I followed a schematic blindly and need to figure out how to...
Jul 29, 2026
Apple Lisa 3d Case Project
OOPSIE! I thought it was outputting some custom resolution that fit 1080p, something on the order of 640x400 on the 'Books which is...
Jul 28, 2026
8*24 GC incompatible with Display Enabler v2.2.2
This is unlikely to be useful information to anyone. However, in the event someone is trying to get around an incompatibility with the...
Jul 28, 2026
V
VeryVon
What happens if you try the 1/8 audio jack with an external speaker? Same issue? I believe both the LC & LCII have 8-bit mono sound...
Jul 28, 2026
jonschultz
Mystic Color Classic Screen Distortion
Another place to check is on pin 7 of the TDA8172. You should get around 5V here. What you’re seeing could be related if it’s way off...
Jul 28, 2026
christcc2
Well I just rebooted the machine and now it looks like this:
Jul 28, 2026
