L
lsi-aigisx86
Performa 575 Whining/Squealing noise, analog board
Macintosh LC & Performa
Hey ya'll. I had recently acquired a Performa 578 off of market place and brought it home with me, it does function, and despite being...
Aug 6, 2026
E
Eradicator
I never fixed the scanner freezing as soon as I moved the selector to regular 8mm. I could switch back to super 8 and it worked fine...
Aug 6, 2026
campbellashe
Troubleshooting Macintosh Portable after loading 12V line-- self inflicted.
I tried injecting 2.4 volts via the R151 after isolation. No chime and no change. I'm moving to Hybrid replacement next and awaiting my...
Aug 6, 2026
Apple Lisa 3d Case Project
Finally got the Logitech M185 in and did some tweaking of my design. It took a few tries but I was able to get it to fit. Still...
Aug 6, 2026
D
daanvdl
Let me know if there’s anything else I should measure or scope to help narrow this down for you.
Aug 5, 2026
S
Scouter3D
Macintosh Portable M5126 - Battery problem - Good night :0)
Macintosh Portable
Hi, my name is Tom and this is my first post in this forum. I run a small online homecomputermuseum site and i repair a lot of vintage...
Aug 5, 2026
Elemenoh
@jktw which board(s) do you need to recap?
Aug 5, 2026
thecloud
What printers are you using?
Like @billgoats , I have an ImageWriter II, but it doesn't have an AppleTalk card. It's connected via serial cable to a networked Mac...
Aug 5, 2026
billgoats
I have an ImageWriter II with AppleTalk card, which is always a delight! With both black, and colour ribbons. Then there's the...
Aug 5, 2026
Froggy814
I would try everything in my power not to have to replace the PMGR. But of course, it is always a plausibility it is something else...
Aug 5, 2026
campbellashe
Recap: After correcting the J15 power tap wiring, the Portable stopped booting. SYS_RST*/PMGR_RESET* stuck at 0V, F1 good, PMGR clock...
Aug 5, 2026
mmaseda
SE/30 and Lapis ProColorServer 24 (Not 24X)
I have the same board as you so I’ll be following this thread. One thing I notice in the pictures is the 24X has all the jumpers removed...
Aug 5, 2026
Froggy814
A Hitachi HL400 portable in the e-waste? Yes!
Wow! Cool find!
Aug 5, 2026
Finds & Conquests
Seriously, I lifted the lid to have a scrounge as per usual and... Well, I found this: Even had the power brick with it! There's some...
Aug 5, 2026
