L
litriSE
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next?
Compact Macs
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next? Hi...
Aug 13, 2026
G
Grand_Viz
Macintosh Performa Plus Display Inquiry
Monitors
Hi all! Right before I was beginning to work on trying to fix the broken power button on a Macintosh Performa Plus Display that I...
Aug 13, 2026
V
VeryVon
Ok here's the floppy version I believe. Volume is set to 5/7. It sounds a bit quieter than the CD version at the same level.
Aug 13, 2026
Michael
BlueSCSI Toolbox - NeXT Edition
Hi @eric , if needed, I can help you in testing your application, if you can compile into a NIHS package. I do have NeXTSTEP running on...
Aug 13, 2026
Michael
BlueSCSI NeXT quesiton
Thanks @Purdy , thanks @JdM74 , following your advice (older firmware, some changes in the .ini file) I got my 712/100 running NeXTSTEP...
Aug 13, 2026
Concorde1993
Can't Get 256 Color to Work (OrangePC Card in a IIfx)
Geez, no ideas? What do I have to do, join Vogons? 😳
Aug 13, 2026
I have it on my TODO's for far too long, spent some time tonight and got almost everything done for a cli # hostinfo Mach kernel...
Aug 13, 2026
Froggy814
I think finished routing most of the Traces, decided to add an expansion header as well, maybe for DEBUG purposes? It just connects to 4...
Aug 13, 2026
Huxley
Hi @eric ! Hope it's okay to revive this old thread, but I'm super curious: did the NeXTSTEP version of the BlueSCSI Toolbox ever evolve...
Aug 13, 2026
No, actually, now that you've explained it, it sounds like you're zapping PRAM on each reboot, and that would also work because it sets...
Aug 12, 2026
Mr. Macintosh
Sorry for the explanation not lining up, but what you replied with was exactly what I was trying to say. I've been able to simplify the...
Aug 12, 2026
7.5.3 is ... a choice :) I suppose you could get 7.5.2 on there, though nothing earlier than that, of course. But I ran into fewer...
Aug 12, 2026
