E-Machines Big Picture Card w/Mac SE Interconnect - Cloning Possibilities?
Hardware
Pulled this Card/Adapter out of storage to see if it might be a cloning target. Found my old thread about this one over at the MLA...
Aug 13, 2026
Can you insert some quotes from previous posts to remind us what this is about? EDIT your post, click the [ ] button to toggle off BB...
Aug 13, 2026
Mr. Macintosh
@ClassicHasClass @joevt @Rairii Is this the data you were looking for the Windows NT register dump? VENEER is loaded at: image_base =...
Aug 13, 2026
techknight
No, when you lay out an RP2350 or likewise design, you have to follow the layout guidelines exactly to a T, or your DC converter doesn't...
Aug 13, 2026
L
litriSE
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next?
Compact Macs
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next? Hi...
Aug 13, 2026
G
Grand_Viz
Macintosh Performa Plus Display Inquiry
Monitors
Hi all! Right before I was beginning to work on trying to fix the broken power button on a Macintosh Performa Plus Display that I...
Aug 13, 2026
V
VeryVon
Ok here's the floppy version I believe. Volume is set to 5/7. It sounds a bit quieter than the CD version at the same level.
Aug 13, 2026
Michael
BlueSCSI Toolbox - NeXT Edition
Hi @eric , if needed, I can help you in testing your application, if you can compile into a NIHS package. I do have NeXTSTEP running on...
Aug 13, 2026
Michael
BlueSCSI NeXT quesiton
Thanks @Purdy , thanks @JdM74 , following your advice (older firmware, some changes in the .ini file) I got my 712/100 running NeXTSTEP...
Aug 13, 2026
Concorde1993
Can't Get 256 Color to Work (OrangePC Card in a IIfx)
Geez, no ideas? What do I have to do, join Vogons? 😳
Aug 13, 2026
I have it on my TODO's for far too long, spent some time tonight and got almost everything done for a cli # hostinfo Mach kernel...
Aug 13, 2026
Froggy814
I think finished routing most of the Traces, decided to add an expansion header as well, maybe for DEBUG purposes? It just connects to 4...
Aug 13, 2026
