PL212
BlueSCSI Toolbox - NeXT Edition
Wow, was not expecting that level of polish! I don't know your comfort level with sharing the source code, but i'd be glad to try and...
Aug 14, 2026
Have a FAT build for 68k,x86,SPARC that works on 4.2 - I'm going to guess 3.3 will need a lot different GUI/WM calls.... Obviously some...
Aug 14, 2026
Froggy814
You are soooo right... This is now something I will let the experts do, instead of soldering the pi together and designing that myself...
Aug 14, 2026
Scott
OK, what hardware do you have it on? I can tell it's System 7.5 from the menu bar. I have never tested Midnight Rescue under System...
Aug 14, 2026
No, we have this part. We need the full register dump. Thank you for trying it, though - proves it's not just my hardware, but what ROM...
Aug 14, 2026
Mr. Macintosh
Done, sorry should have added that context. 👍
Aug 13, 2026
E-Machines Big Picture Card w/Mac SE Interconnect - Cloning Possibilities?
Hardware
Pulled this Card/Adapter out of storage to see if it might be a cloning target. Found my old thread about this one over at the MLA...
Aug 13, 2026
Can you insert some quotes from previous posts to remind us what this is about? EDIT your post, click the [ ] button to toggle off BB...
Aug 13, 2026
Mr. Macintosh
@ClassicHasClass @joevt @Rairii Is this the data you were looking for the Windows NT register dump? VENEER is loaded at: image_base =...
Aug 13, 2026
techknight
No, when you lay out an RP2350 or likewise design, you have to follow the layout guidelines exactly to a T, or your DC converter doesn't...
Aug 13, 2026
L
litriSE
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next?
Compact Macs
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next? Hi...
Aug 13, 2026
G
Grand_Viz
Macintosh Performa Plus Display Inquiry
Monitors
Hi all! Right before I was beginning to work on trying to fix the broken power button on a Macintosh Performa Plus Display that I...
Aug 13, 2026
V
VeryVon
Ok here's the floppy version I believe. Volume is set to 5/7. It sounds a bit quieter than the CD version at the same level.
Aug 13, 2026
